Nice big rolls of wide coax seal
I thought it was a very good price. I usually only find the 1/2" rolls which cost around 5 bucks.
This one roll should last me a long time.
Here is something to consider when sealing your coax connections.
I've found this tape type product messy on un-installing some antennas I've done. It's hard to remove and save parts for re-install, and I don't find that it's particularly effective at keeping water out of the coax after it gets old. This is because it can and does crack as it dries out, and water can get into your coax from above the feed point. On an old install you can actually see the marks left on parts below the tape installation...where nondrying solvents have leached-out and run down the antenna or mast below.
IMO most water gets into your feed line running down the line and other parts into the connector, and it's not from water outside getting inside the connector...unless submerged. Air gap type coax (9913 and others) and some foam type coax can even siphon water in the line in the typical install when coax is running vertical.
When I've found this product old and used on both sides of the feed point, as in a V58, Vector or Sigma4, or I-10K type feed point the product is always a mess, near impossible to fully remove, it's dried out, cracked and probably not stopping any water, and sometimes looks to have actually trapped water around the connector. It will make a nice seal however when it is fresh an recently installed.
With the A99, Imax, GainMaster type antennas, if you seal below the feed point you're really asking for trouble by actually covering up the drain hole and trapping water inside the tuner area, and that's not good. These type antennas all have drain holes in the very bottom where the coax connects. And you can't use this product effectively above the feed point, because that area is enclosed inside the mount. Above the mount and inside this area is probably where most of the water access occurs...allowing water into your feed line.
Just think about it, the area around a PL259 that can be susceptible to water in typical installations is around the top of center pin which is almost always pointing straight up, and if the SO239 above is not also protected then water can go straight down into the coax as water runs constantly down the antenna when raining, or there's heavy due and humidity that cause heavy condensation.
I recommend a non-conductive teflon filler product called "STUF" that is cheap, goes inside the coax connector easily, without mess, never hardens, and a very little bit will shed water like off of a duck's back.
Look it up on the Internet at some ham dealers including at: www.aesham.com.
Without due consideration, this tape product might be like buying a fishing lure...it might look good to you, but does it really do the work and look good to eat to the fish?
I have used this stuff for many years and have never suffered any ill effects.
I use Dow Corning sealant (been around since WWII) then wrap with Scotch 33 or an equivalent, then use coax seal followed with a wrap of silicone tape.
When I was an Outside Wire and Antenna Maintenance Specialist in the USAF, this is the same procedure we used. Prepped installs like this all over the world in different climates. Very rarely did we have any moisture ingress.
I would never use this product just by itself. When intalled as a middle layer, it makes for less mess upon disassembly.
It's all in how its applied.
This stuff is used industry wide and is very effective when used correctly. In temps below 65° it helps to warm the stuff up for easier removal. You can even roll a small ball and use it to dab and pull the product off the connection. When applying in cool temps, I'll heat it up first so it's easier to mold.
Each person has their own ways of doing things. I usually lower all of my wires 2-3 times a year to check each joint out anyways. I use pricey feedline and do not want moisture. On beams and such, I seal as best as I can.
Main thing: don't use it by itself.
I have used it before and always covered it with a tight wrap of either Scotch 88 or Scotch 33 tape. I wrap it with tension and it squeezes the Coax Seal into every nook and cranny of the connection. I just may order a roll or two to seal the bonding strap connections to my coax cables. That is always a hard thing to seal after opening the outer sheath to connect a grounding wire to the shield but this stuff works great if over wrapped with a GOOD electrical tape.
LOL That's refrigeration tape!
We use it to insulate TXV bulbs & lines. What about heat shinking the joints? Will that hold up? Is there a substance that actually goes on the coax connection itself? Where do you put the Noalox? I want this to be the last time my tower comes down.
