A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
radio port is coax from cb radio
cb is output to the cb antenna
car antenna connection i likely would not use myself
once keyed up rotate the tuning knob slowly until you have adjusted for the brightest lamp indication.
Was this a general question on how the device operates,
have you used an swr meter to verify the match and eliminate a badly mistuned antenna or a bad coax?
