Hello all!
I've been experiencing an odd issue with my mobile setup, and came here in the hopes that someone may be able to explain to me what is happening.
My mobile radio is a Uniden 520 (tuned and aligned by Sparky's). I use a D104-M6B microphone, and the radio is run into a Palomar 250 (Yellow face, class AB1). The antenna is a Larsen NMO27C on a Larsen trunk-lip mount.
The Palomar amp is wired directly to the battery with 10AWG wire, and has a short 10AWG ground to a seat bolt.
I attempted to measure the RMS power output of the amplifier using a Dosy 4001 meter. When I power off the amplifier and run the radio directly into the meter, I see about a 5.5 watt RMS deadkey with a small amount or forward swing. When I turn the amplifier on, I begin to see reverse RMS swing on the Dosy (no more than 10 watts reverse from deadkey). What puzzles me is that if I replace the antenna with a dummy load, I begin to see forward RMS swing on the meter, even with the amplifier on.
One other interesting point of note: I asked a friend about 2 miles away to watch his signal meter while I was transmitting with the amp turned on and he reports that I do have forward swing on his radio's meter.
My question then, is the following:
Given the situation, does it seem that there is indeed a problem with my equipment, or is the meter simply giving inaccurate measurements when connected to my antenna?
Any pointers are greatly appreciated. I just want to ensure that my setup is operating as efficiently as possible!
