Ok guys, I'm stumped
  • Thread starter Thread starter RollingRadios
  • Start date Start date
R
RollingRadios
Guest
I have 3 Shure mikes that I can't get to modulate on a 4 pin configuration.
Each has a white, red, green, and black, no shield wire. Two of them I managed to get transmit in three different ways, but the third squealed in tx, all 3 would not produce audio.
Before pulling the rest of my hair out, my thought was the black wire may be rx and there is no shield. Maybe I would have to go into the mike and switch the black over to ground.
Thx.
Wm. Warlock
"Warlock, 71 in Va"
Rollingradios@aol.com
Mail me your XForce questions</p>Edited by: <A HREF=http://pub86.ezboard.com/urollingradios.showPublicProfile?language=EN>RollingRadios</A> at: 3/31/02 9:24:38 am
Rolling, For what radio, and what Shure mic is it? I will look through my books and see if I can find anything for ya.
fasteddy
CDX-765, PE765, 2SF765
High Country DX, HF Specailist. Del Norte, CO
contact me at pe765@aol.com
</p>
The following is from Ken Thouey's Yellow Book.
"If you have 4 wires: check between the shield and each unidentified wires to see which has continuity in recieve & which has continunity in transmit. (When you have 4 wires & find niether unidentified wires connect to ground; but the do connect to each other -- then you have a relay switching mic.)!
If there are 5 wires you have to experiment to see which wires connect tfor recieve and which wires connect together for transmit. The wire that connects to each other of the others (one in recieve & one in transmit) is "common,"the others are recieve and transmit."
Shure 444 " Controlled Magnetic"
Audio--black
Transmit--white
Ground--shield
Shure 444T "9v Desk mike" (cut gray wire=electronic switching)
Audio--white
Ground--shield
Transmit--black
Recieve--Red
Shure 526T " Power mic 6 wire"
Cut gray jumper wire inside for "isolated" electronic switching.
Audio--white
Ground--shield
Transmit--red
Common--blue
Recieve--black
Yellow--special Johnson CB
I hopes helps. You don't know how slow I type.
Jim<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
The Peddler CDX-356,
Meandering to a different drummer</p>
I guess it didn't help.
Jim <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
Thanks for the replies. I've just got in from vacation and have not had a chance to fool with them. When I figure it out will post results.
Thanks
Wm. Warlock
"Warlock, 71 in Va"
