Ok, I'm going to take the plunge...
  • Thread starter Thread starter WalshU
  • Start date Start date
W
WalshU
Guest
Ok, I think I've finally heard enough about shortwave radios that I want to get one. Right now, I have a Uniden Bearcat 278CLT Scanner, that I use in the house with the stock telescoping antenna, but as everything else goes in the radio business, I want bigger and better! I want to go Shortwave, basically I need to know your guys' recommendations for the best Shortwave radio bases and what kind of antennas I need to have to really enjoy them. I need any info you can give me as I have never really paid antention to the shortwave craze, Thanks in Advance!
Equipment:
Northstar 9000
RK56 mic
Wilson 1000 Trunk Lip
and my baby,
Accurate Power 400 *Gold Edition*
</p>
Guess its a lost cause!
Equipment:
Northstar 9000
RK56 mic
and my baby,
</p>
I am still putting together some stuf for you guy, should have it on here tonight sometime. Surely there are some other people on here that has some ideas as well though. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
</p>
Thanks Charger! I was hoping someone would come through for me. BTW, I thought the post about EEI and Pace on the board that you posted on the 26th was right on the money and very commendable. You did the right thing. I'm glad to be on the side of the Good Guys! You deserve all the sucess you've had so far and you will no doubt achieve more. Thanks for everything!
Equipment:
Northstar 9000
RK56 mic
and my baby,
</p>
WalshU,
I was hoping someone else with more knowledge than I would help you out. As far as a base (table top) radio goes I can`t help you there. They do cost quite a bit of money. I started with a Grundig YB 400. It`s a fun little radio but only mediocre in comparison to other portables. From what I`ve learned the Sony 2010 is about the best if not the best portable for the money. If I get another portable it will be the 2010. I read a post by old #7 that explained synchronous detection better than I`ve ever heard. Wish he would do it again. Antennas? Thats easy. Just a long, long wire. This might help a little.
www.dxing.com/swrx.htm
raven.cybercomm.net/~slapshot/speedx.html
Main</p>
Here are some links for you guy, hope they help.
mayradios.com/worldband_shortwave_weatherband_tvradios.asp
durhamradio.ca/swr.htm
www.grundigradio.net/index2.html
Selecting A Shortwave Radio
There are many different makes and models of shortwave radios, and they vary greatly in cost, features, size, complexity, and other factors. There is no one "right" shortwave radio for everyone. The best shortwave radio for you depends primarily on your listening interests. However, there are some features and specifications you should look for in any shortwave radio you consider. They are:
• Frequency coverage. Shortwave frequencies are usually considered those from the upper end of the AM broadcasting band, 1700 kHz, up to 30 MHz. The minimum frequency coverage you should look for is 540 kHz to 30 MHz. Most shortwave radios sold today also tune down to 150 kHz, covering the longwave band.
• Frequency readout. Most shortwave radios sold today have a digital display showing the frequency the radio is tuned to. A few radios, usually less expensive models, have an analog "slide rule" frequency readout that does not indicate the precise frequency the radio is receiving. It can be very difficult and frustrating to find a station on a specific frequency without a digital display, so a digital frequency display should be a "must" for any shortwave radio you’re considering. However, an analog readout shortwave radio can make a good, inexpensive "spare" radio for traveling, etc.
• Modes. Some shortwave radios tune only AM mode stations, and these can be satisfactory for listening to most shortwave broadcasting stations. However, SSB is used by a few broadcasting stations in addition to ham, aeronautical, military, and maritime communications. A shortwave radio that can receive SSB in addition to AM will greatly expand your listening options on shortwave.
• Selectivity Options. Selectivity is discussed in more detail below, but you need to consider how many selectivity bandwidths you can select. Some portable receivers allow you to choose between "wide" and "narrow" selectivity bandwidths, while some desktop shortwave radios have as many as five selectivity bandwidths. Narrow selectivity bandwidths let you reduce interference from stations on adjacent frequencies, although the audio quality of the desired station will be reduced as the selectivity is narrowed.
• Antenna Connections. Some portable radios come with a built-in telescoping antenna but have no provision for an external antenna. Other portable shortwave radios have a jack that let you connect an external antenna. Most tabletop shortwave radios have connectors for external antennas. These usually include connectors for antennas using 50 ohm coaxial cables and others for antennas using ordinary insulated "hook-up" wire. External antennas normally give better reception than built-in antennas, although built-in antennas are usually satisfactory for listening to major international broadcasting stations. However, built-in antennas give poor results inside buildings with steel frames, like a high-rise condominium or apartment buildings. In such cases, the ability to connect an external antenna (even it is only a few feet of wire outside a window) can make a significant improvement in reception.
Here are some of the terms you need to understand when buying a shortwavr radio. These terms are used to describe the features and controls found on shortwave radios:
Audio filter. This circuit rejects certain audio frequencies in the audio output of a receiver. A bandpass filter will pass a certain band of audio frequencies but reject others. A low pass filter will reject all audio frequencies above a certain frequency. A high pass filter rejects all audio frequencies below a certain frequency.
Automatic gain control (AGC). This circuit adjusts the gain of the receiver to maintain a relatively constant level of audio output from the receiver regardless of changes in the strength of the received signal. Some AGC circuits let you select how fast it reacts to a change in signal strength, such as a "slow" or "fast" AVC. This circuit is sometimes called an automatic volume control (AVC).
Beat frequency oscillator (BFO). A circuit that produces an internally-generated carrier to allow reception of SSB, CW, and FSK signals.
Crystal lattice filter. This device improves selectivity by increasing rejection of signals on adjacent frequencies.
Digital signal processing (DSP). Circuitry in which analog signals, such as audio or radio signals, are converted into digital form, manipulated and processed while in digital form, and then converted back to analog form.
Dynamic range. A measure of the strongest received signal that a receiver can handle with overloading or distortion. It is measured in decibels. A minimum satisfactory measurement is 70 dB; over 100 dB is preferred.
Memories. These allow storing of frequencies of favorite stations. Some receivers allow storing of mode, receiver bandwidth, etc., in addition to frequency.
Noise blanker/limiter. This circuit reduces noise due to electrical equipment, lightning, neon lights, etc. Noise limiters are simpler circuits that limit the maximum strength of noise pulses, while more complex noise blankers actually silence the receiver during noise pulses. While this circuits can help reduce noise, they cannot eliminate noise and often introduce some audio distortion.
Notch filter. A notch filter removes a very narrow slice from a received signal, either from the radio frequency itself ("RF notch") or from the audio output ("audio notch") of the receiver.
Passband tuning. A circuit that allows you to move the selectivity bandwidth above or below the frequency to which the radio is tuned. This is often helpful in reducing interference.
Product detector. This is a beat frequency oscillator with enhancements for improved SSB and CW reception.
RF attenuator. This circuit reduces the sensitivity of the receiver in discrete steps, such as 10 or 20 decibels.
RF gain. A control that permits the sensitivity of a receiver to be continuously varied.
Scanning. This feature lets the receiver automatically tune through a desired frequency range, stopping on all frequencies where a signal is present. This feature is sometimes not too useful on shortwave, since atmospheric noise can also can mimic a radio signal.
Selectivity. The ability of a shortwave radio to reject signals on frequencies adjacent to the desired station. It is usually expressed as a bandwidth measured at 6 dB rejection points ("6 dB down" or "-6 dB"). For example, a selectivity specification of "6 kHz at -6 dB" means any signal outside the 6 kHz bandwidth will be reduced in strength by at least 6 dB (in other words, the interfering signal is only one-fourth as strong as it would be otherwise). Typical good selectivity measurements at 6 dB points are 6 kHz for AM, 2.5 kHz for SSB, and 0.5 kHz for CW.
Sensitivity. The ability of a shortwave radio to respond to weak signals. It is measured in microvolts (mV). The lower the measurement in microvolts, the fainter the signal the radio can receive.
Squelch. This quiets the receiver audio until the strength of a received signal exceeds a desired level.
Synchronous detection. A circuit that replaces the carrier in a received AM signal with an internally generated replacement to reduce the effects of fading.
Variable bandwidth tuning. This circuit allows the selectivity of a receiver to be continuously varied.
</p>
Wow, that was a lot to read, after examining it then, I think that I may just use a portable in doors to save myself the cost of the table top model. I think the three big ones in the running with me are the Sony 2010, the Sangean ATS 909, and the Grundig 400. I guess what I need to figure out is what is the best radio in this range? I want to have SSB, and the broadest band possible, and I also want to have an external antenna connector. I really am leaning towards the Sangean 909, but any comments would be apperciated. Thanks Charger and Main for all the info! also are there any mods that should be done to these radios or are the pretty much good performers without the tinkering? Thanks!
Equipment:
Northstar 9000
RK56 mic
and my baby,
</p>
Hi Walsh,
I owned the 909 or should I say radio shacks version. Worked really well!
There is a mod out there for this radio to get rid of the chuffing sound while you change frequencies. Couple of other mods as well but forgot what they were.
Real nice to have a tape player built in so you can record some of weird stuff you hear out there in the short wave world.
SSB worked really good....... even recieved those really low frequencies below the broadcast bans so you can listen to all the radio beacons out there.
Also had a input for external antenna.
Hope this helps,
JP
</p>
Chillin, in an unrelated note, what did you end up getting for a radio? a Northstar or what?
Equipment:
President Lincoln
**Coming Soon**
Northstar 9000
**Is for Sale!**
RK56 mic
**NEW** Predator 10K
on a Triple Magnet Mount
and my baby,
</p>
Went and bought a RCI 6900 Fhp for $400 mods included. A really nice radio....even had a knob added to the side for the internal echo board. By the way why are you selling your 9000?
L8ter,
JP
</p>
I bought a Lincoln, and I don't have a use for the 9000, I just sent it back to the factory service center, had it checked out and packaged it up, and now I'm waiting for it to sell, I'm selling it for $275 shipped, comes with all the accessories, has been scoped, converted for 8 bands of channels, and comes with a Chrome RK56 mic. Anyone interested in it drop me an email at: layne@neo.rr.com . Hope you're happy with the RCI, I hadn't seen you in the chat for a while so I wanted to know what you got! Later!
Equipment:
President Lincoln
**Coming Soon**
Northstar 9000
**Is for Sale!**
RK56 mic
and my baby,
</p>
