Hello everyone, I'm hoping you will all bear with me for a little bit, as you all seem well versed in this stuff, but I'm just sort of getting used to the lingo. I hope I'm not asking something which I should just Google, however I haven't yet found anything in simple enough terms for me online, so I hope you'll excuse any forum faux pas as well. My dad was gracious enough to lend me his old Hallicrafter S85 and in Houston, with an improvised wire antenna I was able to pick up the NHK out of Canada. Now that I got it home, I wanted to put up a more robust antenna, but unfortunately I'm not real knowledgeable in this stuff at all.
I was going to place it along this wall since it has lots of space and is right next to the radio, but I think maybe all the elctronics would cause interference. I have tried to read up a little on antennas, and this source has proven quite helpful. Going off of that, I was planning something like this but I'm not sure this would be good, since it would be an outdoor antenna indoors? Failing that, I was also thinking of maybe doing a loop around my ceiling, however, I have a stereo cable and a CAT6 cable going diagonally across my ceiling already, and maybe this could cause interference?
Also, many online guides mention the antenna to radio connections being co-axial, however my radio seem to just be the screw down types for two simple wires. It's kinda hard to explain, but there's a picture in the third page of the instruction manual. Sort of confusing.
Is there any advice for someone in my position?
