Older President JFK export 3 band , 6 pin mic
Chevboy0167
Apr 5, 2017
323
214
53
49
Howdy folks. I have said radio in title on the bench and have no mic for it. CB Tricks shows this rig has a standard 4 pin. My JFK has factory 6 pin. Does anybody have the proper pinout? Does this radio have the same pinout as the Lincoln II, Grant II or similar? Thank you much in advance.
1 Modulation
2 RX
3 TX
4 NC
5 Ground
6 NC
This Pin-out covers the 6 pin President, but there's one major difference. The older President's use a Dynamic cartridge and the newer President's like the JFK II use an electrolytic cartridge. I believe the JFK you're talking about uses the old school 500 ohm dynamic. Pins 4, 5 and 6 are used for up and down buttons in some models. The middle Pin 6 in that case has voltage,avoid it.
Reactions: kaos513
