Omega Force 45 HP
My 959 runs pretty warm during extended transmissions on the left back and the left rear side of the radio. It's still set at 4 watts am dead key and 12 watts SSB power with the 2018 mic cranked all the way up as well as the radio's mic gain. I've been thinking about installing a heatsink :pop:on it or at least mount a fan on the back to blow on the radio.
A single heatsink with a small fan will suffice . . .
Heatsink
Know where I can purchase one? Whatever is mounted on the left side of the of the radio near the back gets pretty warm as well. I'm thinking that with that much modulation,whatever the audio goes through gets hot too. My Realistic TRC-428 Nine Scan cb has a two rows of holes on the speaker case near the rear with some kind of black air permeable cloth glued over the holes on the inside of the case for ventilation. I'm also wondering if I do the same type of deal on the 959 case,that would aid in it's cooling. Of course,the heated air would have to exit out through the faceplate via the knob shaft holes. I haven't made a XCO for the crystals yet.
Sounds like some connections/wires are intermittent.
If you just bought it and it is under warranty, send it into the Warranty Repair near you - after you get an RMA from Sam Lewis @ RF Limited.
Robb you want it to go the Chris in Ontairo Calif, he is the Magnum guru
Dunno if Chris issues the RMA; I know Sam does . . .
Galaxy said they don't sell parts but suggested jtronix.com. Rfparts.com and maycomcomm.com. Thanks.
Never had a problem buying parts from Galaxy before.
You can always buy a non-OEM part if you must.
R&R has been great with me but I have heard a bunch of horror stories about them, even over a small thing like coax, so if your not going there in person I would not deal with them just my experience:crying:
