Palomar elite 450 HD keying circuit problem
Drradio61
May 1, 2021
4
2
13
65
Hello all,
I have a Palomar elite 450 HD with four SD 1446s it has a burnt resistor that can't be identified except for the silk screen on the board that says r19. Does anyone have one of these amplifiers or a schematic that could give me an idea of what the value is of that resistor?
Without digging into my amp notes I would say its a 33 ohm 1/2 or 1 watt carbon film resistor. Likely had to much drive into the amp. Also replace that diode by it, likely a 1N4007 will do just fine, this is likely bad too. Anyone correct me as I am just going from memory.
Reactions: Eldorado828
So an AI google search said this. So I guess you have a range of suggestions to help get it up and running. Good luck.
The stock value for R19 in the standard Palomar Elite 450HD input padding circuit is 100 Ohms (typically rated at 2 Watts, non-inductive). [1]
However, its functional value often depends on the specific modification or version of the schematic you are tracing:
  • Stock Attenuator / Padding Network: It serves alongside a 27 Ohm resistor to form the High/Medium/Low power input drive selection.
  • The 5-Ohm Bias Circuit Modification: In community-modified versions of the Palomar bias schematic (such as the popular WorldwideDX Regulated Bias Tracing), techs frequently replace the stock 100-Ohm resistors in the branch lines with 5-Ohm resistors. Leaving them at 100 Ohms severely restricts the current, preventing the TIP-31C pass transistor from supplying enough forward bias to the gates/bases of the pills. [1, 2]
It also came up with this older thread on this amplifier.
