Palomar Skipper 300
jammeejoe
Aug 8, 2005
50
East Texas
Would anyone know the number of turns and the diameter of the driver and final tuning coils on the skipper 300? I bought one and it is set for another band. I tried winding some using the pot luck method and helped it but I would like to know the right size. Thanks
Driver, 6 turns 1 1/2 inch diameter, Final, 4 turns 1inch diameter.
Tune the amp for max and check the position of the gangs, they should be at half mesh.
If the gang is fully meshed, that means you need more turns on your coil. If your gang is fully open, that means you have too many turns.
Do not try to adjust the output or driver tank coils with the amp powered on (but you knew that!).
