pcb trace problems
Trainwreck
Aug 4, 2012
50
I recently was removing the finals and driver from my galaxy 44 ( which is fairly old ) and in the process of removing one of the finals legs when the copper trace came of the board as well. How do i go about rebuilding the trace or is the radio junk now? Really would like to fix it cause its one of my favorite radios besides my galaxy 33hp. Thanks you for your valued information
You have to be careful and quick when soldering with these boards if you pull copper traces or joints of the board you at times will be fighting a losing battle and it can get real frustrating when theres nothing to gld the solder. Small runs of wire works great but again plan it out and get it done carefully or things can get even worse.
