Thank you for the info. Little concerned for the "Not Compatible" remark in the description.
Well yes, looking at the column on the right in the Astatic mic manual it says " Not compatible" with the SE Plus series at that pinout since that is a voltage line. The column on the left shows the same mic wiring for many different Pearce radios including yours using other Astatic mics.This was the N/C I was referring to.It was not " No Connection",but thanks for the reply.
The Pearce-Simpson Panther SSB uses the same Uniden "Coffin" mike found on many different models of Cobra, Midland, Robyn, etc. radios. The only difference is the "Pearce-Simpson logo on the front (and of course the mic wiring). Many P-S radios used the same mic, and you should be able to find an original on EBAY or CL.
- 399
