pi Tank Tune & Load Values for 80M
Naysayer
Solder Balls
I Support WorldwideDX.com!
Mar 6, 2020
372
280
New York
Homebrew 4cx300a amp grid driven:
I found a better air variable for my Load cap. Installed and working OK 10-40M but I need to estimate the C values for 80M. New Load cap is another 2 section Johnson, 3kv rated but the smallest section <10pF and both sections equal 205pF. I use a CRL 2500 series, progressively shorting switch to add capacitance for 40 & 80m. I had 40M working fine on the old load cap somewhere around 320pF and it working OK again in that range so that’s my starting point on the Load.
Generally I noted my Tune and Load C values are lower than the values I see on other amps using small Tets. ‘Stray Capacitance from Roller’ causing the lower values is what AI suggested. My Vacuum Tune only goes to 110pF and it’s enough for 40M with pF to spare. Have a latching Kilovac if needed for 80 on the Tune. I will use CRL 6kv ceramics as padders (100, 200 & 300 values on hand).
How to estimate the Capacitance needs for 80M? My best guess is somewhere below 900pF on Load and <250pF on Tune given I have 40 working with <350pF on Load. Is it reasonable to double that for 80 to start?
Pride’s DX-300 uses a 3 section air V with 450pF max each (1 tube) but there’s no minimum value I could find online. It looks at least 40-ish if not higher. On 10 meters my tube pair needs <20pF on Load so adding another tube has me in unknown but lower pF territory.
Am I stuck with trial and error?
Since none of the tube guys are replying, I'll take a crack at it. I'm probably wrong. Maybe one of the guys here that do this can chime in. Edit: I am NOT a tube guy.
Commence guessing: I assume one tube, AB, 300w, don't know your plate voltage. But if I assume 2000v, that's 1800v peak swing at 90% supply swing, and that's 1273V RMS voltage swing. Ohms law says 1273^2/300=5400ohm for the load resistance.
I don't know what your inductor value is in the output network, but you basically have a pi network with about 5400ohm on one side and 50ohm on the other. Should be simple to work out the caps once you have the inductor value.
Reactions: Naysayer
I just did a sanity check using the DX300 schematic as a baseline. Since it uses the same voltage, I assumed the same load (well, i put in 5kohm this time) and 3.5MHz. I see in the A position, the load capacitor has a max of 450p x3 + 160p x2 for a total of 1.67nF max for the load capacitance. On the tune side there is 110p + 165p for a total of 275pF max at the plate tune. I then calculated the total inductance based on the diameter and turns listed in the schematic plus the approximate length of those coils via pictures online. That came to 12uH, and in position A, we have all turns active. Off to simsmith to see if it matches.
yes it does, and we didn't even need the max capacitances available either.
Thank you Brandon. I’m going to make another try this afternoon if possible.
The online calculators wanted values I did not understand and was unable to provide. Your walk thru showed me how to use and apply that formula.
I’ll report end values but it will take time, it is ungodly hot in NYC so life slows down a bit here. Thanks again for the lesson.
I think when you use a website like this:
you will notice that at 5000ohm to 50ohm, the recommended Q that AI provides (about 10-15) will result in an inductor value that is larger.. Trying to solve with a 12uH inductor and a low Q returns an error for a pi network. It suggests an L match at low Q. Just raise the Q until it puts out an inductance that you can live with. It requires a Q of about 20 at 3.5MHz to use the 12uH inductance I estimated from the amplifier photos online.
It is important to know that a higher Q = higher circulating current, higher capacitor voltages, and the adjustment becomes much more critical. This means don't go nuts with the Q in order to use a smaller inductor.
repeating my disclaimer: I am not a tube guy and I have not done this before. Just going by what I think I gathered after few quick google searches and talking with AI and playing with simsmith.
Edit: seems the guys here actually building kilowatt amps are afraid to chime in. I find that a little odd, but ok.
not to ramble on, but [this paper] talks about the formulas for calculating a transistor and a tube Rload, and in this paper, it uses the formula Rload=Vplate/(k*Ip). It then shows that k for class AB is 1.6, and when I punch that in with the max plate current of .25A, we again get 5kohm for Rload. Just another sanity check.
edit: with another great amp building paper that also gets into the pi network [here]. It gets into finding the tap points too. This stuff is making me want to play with tubes now.
And another [here]. There is no shortage of info out there. I'll stop linking them now, just gotta search for it.
Reactions: Cable Guy
Got it. My Tetrode project has drained the Brain Trust here over the past few years so, I'm fortunate my membership has not been terminated, lol.
Thanks again for filling-in some of the blanks on the formula and process itself. I will report back but it will take some time. My Tune cap only goes to 110pF so padding at 2.2kv a bit more complicated.
EDIT:
I can measure 10M inductor and the roller's value is published. It was the calculations set forth in your first Reply that stopped me. Going to run through that today. There will be more. thank you for pointing me in right direction.
Reactions: brandon7861
If 2.2kv is your plate voltage, I think your padding caps will need to be higher than that.
I found the diagram for ACOM 1011 (grid driven 2x 4cx250). It works on 1.8 to 30MHz. The diagrams pi network is legible and shows 790-920pF on Load for 80m for my 2 tubes. My Tune values need another 100pF for 80.
I'd never seen a Pride amp in-person or used on 80m but the max Load C of 1350pF seems high but then again, 80m is a big place.
I did apply the formula and I'll stay aware of the possibility that my inductor may need tweaking but I think I'm in the ballpark. Thank you Brandon. Time to test circuit mods.
Summer Heat slowed me down this year. I had to abandon 80 meter plans because I can't make it work antenna wise. My OCF is maxed-out at 95' total. Recall I'm a city ham. I avoid ant traps.
Made many improvements on amp though. Transformer for low V power upgraded from 1/2A to 1A and re-configured regulated and unregulated supply board for tuned input relay selection, internal fans, meter lights, etc. Re-wired filament leads to a more appropriate wire size/type. Reconfigured the SSR control of plate voltage relay (B1B soviet which will work on 14v which surprised me). That allowed removing 24v so everything 12-16vdc, less parts, more reliable.
Added inductor to AC blower runs a bit smoother (triac dimmer speed control)
Overall goal here replacing the 4cx300a for 300y's. Have a NOS pair unopened Green & Silver can mismatch but close enough for homebrew. Using another set of used Y tubes until I'm ready to open the cans. So ... Screen V and Bias revalued as well as the standing current for Tetrode Boards which led to replacing the 3 large power resistors G3SEK used to manage standing current for Screen regulation (finding one's own mistake is a good learning experience). Looking back I'm surprised it worked at all but after several years, I finally understand his design for Screen protection via standing current. The values I settled on for anyone familiar with the Tetrode Boards are: 11k for R13; 3.5k for R14 & 830R for R14.
That's for two 4cx300Y's at 400v.
It takes a lot to enable QRO multi-band, even when it's only 10-40. Something always needs attention. Conditions this Summer are not good. Hoping for a better Fall-Winter.
n2eye
n2eyeFocusing on adoption‑related discussions, I found that players consistently emphasize transparency and ease of use. They explain how pets are purchased, whether the shop interface is simple to navigate, and if the overall process feels reliable. In several threads, buy adopt me pets online was mentioned as a straightforward option where users felt confident about their purchases. That kind of realistic feedback makes the platform appear dependable, especially for players who prefer clear and efficient systems.
