PL259 Re-Wiring
  • Thread starter Thread starter CQDX CQDX 927 ONTARIO CAN
  • Start date Start date
C
Guest
I have a coax that needs to be re-wired. I have the PL259 screw on.... How can i do a good job on it... I have tried and tried and still not getting any reception....
Can someone help me... Mabye a website or something...
Thanks
927
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":(">
Im looking on how to install the PL259 connector, and not do a Shi* job....
<img src=http://home.comcast.net/~shockwav/canada3.gif ALT=":@cnflg">
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=cqdxcqdx927ontariocanada>CQDX CQDX 927 ONTARIO CANADA</A> at: 12/1/04 6:59 pm
Thanks
927
There are lots of techniques/opinions find one that works best for you. Here are a few ideas.p067.ezboard.com/fworldwidecbradioclubfrm94.showMessage?topicID=28.topic
<hr />73, Mike
</p>
Personally, I don't like the screw on type. Learning how to solder them on is well worth the effort. However, if you don't have a soldering iron/gun, then you're kind've stuck with the screw on type. What type of coax are you attaching this to? Do you need to use a reducer?
</p>
</p>
You're going to need a reducer with that. Did you get one? Also, if you make an investment in a soldering iron, get some extra coax and and connectors to practice on, it'll pay off in the long run. Learning how to solder connectors takes a little practice, but it's well worth it.
</p>
</p>
look at the back side of the pl-259. If the diameter of that is much wider than the coax you're going to use, then you need a little collar that fits inside the pl-259 so that it fits properly. That little collar screws into the connector and is called a reducer. Now that I'm typing this, I remember seeing some screw-on PL-259's that already had the reducer built in. That may be what you have.
</p>
</p>
