plans for a 2m/440 vertical ground plane, something with gain?
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
I want to build a 2m/440 ground plane, I have a decent amount of aluminum in the garage and would like to use it...
Any ideas? Basically I have been using a 2m j pole on 2m and 440, but it's kinda dead on 440...
Hello, just for the sake of stealth I built a small quarter wave antenna using an so 239 and a vertical and four ground radials. I'm using it for the 220 MHz band. I still need to trim it a bit as I left the radials a little long. I just used some pieces of coat hangers :) the swr is sitting high at 3.1 but it managed to get out about 15 miles at 10 feet high lol. I'm sure you have seen the plans to make this antenna before. I just thought I'd share, I'm looking forward to see if I can get the match down lower hopefully :)
Sent from my iPhone using Tapatalk - now Free
Something like this?
Probably the simplest method of 'hearing' more on 440 or 2 meters is by raising your antenna higher. Depending on an antenna's environment, a few feet in extra height can certainly make a difference. You have to moderate that with what's practical though, sometimes it's just not very practical to get an antenna higher.
VHF/UHF signals don't bend all that much, they are a 'line of sight' sort of thingy. You can see further by getting higher (on a ladder! :)) right? Curvature of the earth etc. HF behaves more like your ears, sort of. You can hear around corners when you can't see around corners.
A 1/4 wave antenna has no gain, it has a slight 'negative' gain. A 1/2 wave antenna also has no gain, but it's the standard other antennas are compared to. But, that 1/2 wave antenna does have more 'gain' is compared to a 1/4 wave. A 5/8 wave antenna does have some slight gain when compared to a 1/2 wave. From there, because of how tghe radiation pattern of an antenna is 'shaped', where/how the signal is sent, the typical 'longer' antennas seldom put that signal where you intend (or where you want to get it from).
So, the typical way of getting more gain is either by making the antenna directional, as in a beam, or by 'stacking' elements on top of each other. When you do that stacking it's called a vertical array. It starts getting electrically complicated because you have to phase those 'elements' to get the signal to each of them at the same time to produce the desired radiation pattern. (It also starts getting expensive because of the mechanical aspects of building such a thingy.)
I doubt if I've said anything here that you haven't heard before, and I don't have the measurements for any particular antenna to give you. Making a vertical array a multi-band antenna is certainly possible but it's always a compromise. If that compromise is better than what you have now, then it's a benefit, right? Then all you have to do is not pay any attention to your wallet screaming! (That's the real trick!)
Good luck.
