First of all, YELLING into the mike will not make your signal louder (or prouder). It makes you sound simply AWFUL and
does nothing to make your audio "better". FM transmission simply does not respond to "modulation" and, indeed, is referred as "deviation" as the FREQUENCY deviates while the AMPLITUDE of the spoken word, etc remains constant. That's why it is called FREQUENCY MODULATION, fer heaven's sake!
Also, don't speak right into the mike, but ACROSS it! This will avoid "whuffing" the mike and the heavy breathing sounds that often annoy the dickens out of your listeners!
I hope this is info you can use and it is not something that will people will take as negative criticism! It is posted to help you, not hurt. And I'll bet there are other people that find yelling, mike 'whuffing" and panting into the mike objectionable, too! Use this info to make your amateur transmissions more enjoyable for all!
CWM
