Polamar Elite 250 HD
If you're only going to be running the amp off the power supply I wouldn't go with less than a 30 amp, but you could probably get by with a 20 amp.
Agreed. If you pop the cover of that amp you probably will find a 20 amp fuse on the board where the power input wires are.
