Portable Radio set-up for out door use.
Grogan
Oct 1, 2011
1,139
364
93
Southern New Jersey
Was thinking of setting up a portable radio in one of those aluminum Cases from the Home depot.( looks like a briefcase ) Mount a radio small power supply make sure the case can close carry it back in the house when I am done or chance of rain etc.. Was going to set it up with an Imax 2000 moderately mounted maby 20' legnth of pipe for use by the pool Or I could go stealth with a Radiowavz bazooka antenna .( don't worry I am ground-fault protected. I think I would spend more time by the pool. Could also keep a cig plug adapter for a grab and go radio..:huh:
I now have the Bearcat 980ssb I could buy the wireless mic. Radio room, walk thru kitchen then outside. and 50' to the pool. Question will the Mic work that far? :pop:
If you decide to go with the case, get a Pelican Case. They are impact fiber reinforced fiberglass, completely waterproof, got handles, easy to open and close, and any size you want from small to trunk size and custom sizes and shapes.
I have had one for years and still use it almost daily for my Cameras. You could easily drill a hole in it and insert an SO-239 with a weather cap on the back side. I can say from experience, these cases are strong. probably stronger than any thin metal case.
