Seems like that PLL is experiencing two seperate issues. Changing the VCO with the varactor steady should make it fall out of lock, its not. Thats problem #1. The other problem is that the only way TP1 can have full rail voltage is if pin 19 is open.
This doesn't necessarily mean the PLL is bad, it might simply mean that it isn't getting power. I assume these two pins are open collector, and if the PLL supply is dead, both of these features would be acting like open circuits.
When you get back to it, verify the supply voltage at pin11. I have a hunch it is dead, either from a bad cap, or that zener being shorted.
