President Lincoln Tuning problem
snichols
Apr 26, 2009
3
65
Hi,
I have a President Lincoln and the tuning knob has gone haywire. Sometimes it doesn't change channel as you click, then it goes backwards or skips a channel.
Is it the channel switch that needs changing or something else?
Thanks in advance!
Cheers, Steve
UK
Hi,
Thanks in advance!
Cheers, Steve
UK
channel selector switch is bad.if you cant find a new one for the lincoln,(not available from uniden anymore) get a replacement from ranger for the 2950,its the same part.
President Lincoln channel selector
Thanks - any idea where you can get them from? They seem fairly scarce in the UK.
Steve
If Cleaning dont work..
I have been able to bore a shallow hole in between the 2 green wafers and inject contact cleaner, that usually cleans out the oxidation.
If that dont work, you can get replacement controls from:
t they are available from CB world lots of uniden parts.
CBWorld.com
541-928-1952 (m-f 9am-6pm)
customercare@wearecb.com
Uniden Part Number BSRY0404001 Channel Selector for HR2510
Roger
Problem solved
Roger was right. I drilled a small hole, big enough for the nozzle of my switch cleaner. After a couple of attempts I managed to get the switch working perfectly again.
I also took the opportunity to strip out the LCD and replace the white
backing paper, which I had stained with a previous overzealous application
of switch cleaner when trying to sort the switch out.
Looks and works like new now and is busy monitoring beacons from around Europe on Sporadic E as I write this.
Thanks, Steve G0KYA
:thumbup:
