President Zachary T.
  • Thread starter Thread starter fortymobile
  • Start date Start date
F
fortymobile
Guest
Here is a link
4040mobile™
</p>
I have a newer Zachary T. with the 2816 ic chip. What all can you do to this radio? and how do these radio work transmit and receive wise?
</p>
Isolate pin 9 on the pll for a 5kc drop.
Connect pin #20 to pin #21 GROUND.
Solder a wire from pin #9 to one side of a SPST switch.
Solder a wire from PCB GROUND to the other side of the switch.
If all goes well this should give you 27.420 - 27.860 Mhz.
Yes, i know 27.420 in between the channel SO use the clarifier for the 5 kc offset.
If you can't get all the frequency coverage then adjust L-14 the VCO coil....you can also use a Expo or Galaxy type kit for more channels ...if you were to do this mod it always seems to help to let the mod take for a few minutes or so before you start to adjust the VCO.
well put freecell. Stabilization ...I sure learned that one the hard way over the years
  • @ heartbreaker3473:
  • @ AudioShockwav:
