I have a TS 500V that is around 15-20 years old. It still works but the pre-amp seems to be broken. This has happened 2 times in the past. Once about 10 years ago and the latest about 3 years ago. I have not been using it since that time. When your using the unit you have to cut the power off on it to receive at normal ranges. When the unit is on the receive is extremely low. Is there something that I am doing that is causing this or is this normal for this unit? Thanks.
