Programming software for Motorola GM300 (download here)
Can you provide a pin out wiring for the rj45 to serial port? Or direct me to where I can buy a pre-made programing cable?
just for those interested, if you dig into OTVDM or VINEVDM (i had better luck with otvdm), you can enable 16 bit applications to run on a 64bit system. I was running both the old and new CPS for a m1225 on windows 7 using otvdm using a usb serial adapter. Been so long that I can hardly remember doing it, but I know it works.
I was just talking to chatGPT about using otvdm files with wine in linux and, although completely irrelevant, it referenced my post here. I was kinda surprised to see it reference me. Never figured that would happen lol
Edit to add: With all the other far more relevant material available online that it could have referenced, it does kinda weird me out a little. Its on a dot-connecting mission.
Just shows you how easy it is to manipulate these AI engines. It then treats information that it scrapes as gospel and then presents to the unwary with confidence.
Yes
Ask the Chat bot a question
Tell it that it's wrong
It will thank you and rewrite the new answer for the next person
Wrong or not
And the cycle repeats
