I have a PS-52KX power supply from Pyramid. I have it less than a year and was running an amp with it. Today it started popping the breaker on the back. I unhooked all devices from the power supply made sure it was turned off and had no shorts anywhere. I pushed the reset button on the back to reset the breaker, turned it on and it hums load and within 2 seconds pops off again.
What should I look for that can be causing this problem?
I did not check the fuse inside yet. the manual says there is a 10 amp fuse inside but if it were bad I would think the power supply would not turn on at all.
Please help, it was expensive and I cant aford another at this time.
AP
AP
