Pyramid 52amp
rockenranger
Dec 17, 2011
104
3
53
I have a 52 amp pyramid pwer supply. that im tryn to sell i got it out today to make sure itr works. the voltage adjustmen was not working right so i order a new one. now it works as it should. but now the amp meter is not working. it wil not show any amp but power supply still put out right voltage ive used it all day to make sure anyone got any ideas thanks
Could be bad solder Joint or loose wire. It is also possible the meter itself is shot (I have one here with a bad voltage meter) What are you asking for the powe supply?
