QRO Conversion for HF 2500DX for 10/11 Meter Operation????
Got close enough to one of these at Dayton to touch it.
'Bout as close as I'll get. They don't seem to break much, so it may be a while before I see one for that reason.
Seems to me they're still in business. Make them think you're a ham, they should be obliged to spill the beans for 10-meter use.
QRO web site
QRO will tell you the 10m conversion if you have a general ticket. You might have to get a buddy to call them up... :) :)
Hello All:
The neat O thing about the DX2500 is that it uses the Soviet 4CX800 Tetrodes, in a grid driven circuit.
With a slight modification to the Control Grid Circuit a step up toroid transformer like the one in Pride DX300 can be used to allow a stock low power radio to drive the amp to its full output power.
The neat thing about Tetrodes in a grid driven circuit, it wont take any power to drive it. The power is applied to a 50 ohm resistor across the grid to allow the radio to see a perfect 50 ohm load.
This tetrode grid drived design allows a step up transformer and higher value load resistor to be used, just like in the Pride DX300 Amps.
Jay in the Mojave
Re: QRO Conversion for HF 2500DX for 10/11 Meter Operation??
High Miler said:
Anyone know the conversion for this band... Probably a simple snip of a wire or something...
Thanks.
I've been looking at the schematics for this amp; what happens when you switch it to the 10/11 meter position? Is the amp bypassed or does it switch into transmit but has no output?
