What does adding this kit to an A99 really do for the antenna. It is advertised to lower the TO angle. Some say it increases the range. Some say it improves the ears and call it an ears kit. Some say it lowers the SWR and increases the power output and call it a power kit. Some say it helps with DX and other say if helps improve local and call it a DX kit or a local kit. Some say it does nothing and call it a waste of money and effort.
There are two different A99's. One has no installation bracket and the kit is a hub and 4 elements. The hub slips on the metal base of the antenna and goes up to the top near the adjustment rings. The newer A99 has a mounting bracket like the Imax and the GPK attaches on the bottom u-bolts on this bracket. It ends up near the bottom just above the feed point. This is a different from the older model. Does this make any difference in the way it acts?
What do you think?
What do you think?
