question about a home made antenna design
  • Start date Start date
my local farm supply store carries that tubing, don't know if you have those type places there though
How much gain you seeing over your old antenna? I like your antenna. I wonder how lexan would work in place of wood?
I think a chunk of lexan the size of that '2 x 4' to hold the antenna would be cost prohibitive. In other words, don't bother sitting down for the price, go ahead and lay flat on the floor, saves time. Varnish the '2 x 4' and parts of the antenna on the '2 x 4'. Ought'a stop any wear'n'tear on the wood and stop the aluminum from rusting. About an 1/8" coating should do fine. Or just 'glass' it. Tint for desired finished color. (Pink)
I can get lexan fairly cheap. I work where its made. I get it for the cost to make it. 2 layers of 1/2 inch thick stacked I would fhink would be plenty strong.
You scored BootyMon. Even if the meters were not telling the same thing when they gave you those reports; they were still getting better judged by the same meter. Relative to those meters. I think you did very well; hope I have the same success when I make one!
Pressure treated lumber will be OK for awhile. Regardless of that - you made it work. By the time you have to change it out for another piece a few years down the road, you may well have found a piece of another stronger material by then.
Q: What is the distance from the tip of the antenna to the surface of the ground?
when i redo the ground radials im going to go to a 4 ft peice of solid %100 recycled plastic 2x6 lumber . ive worked with this stuff in the past building decks and the solid stuff is extremely strong ! its also not affected by UV rays and wont rott or shrink/swell between dry and wet seasons . ill get a scrap/leftover peice for free ;) .
the tip top of the antenna is about 46 feet high . more is more and i got more and can tell a obvious difference so im happy .
