Question for NomadRadio or any other.......
Phil501
CDX-501 back in da mix!!
Apr 6, 2005
217
57
Western Nevada
Hey guys, I just purchased a used TeaBerry Stalker IX 40 with SSB......I haven't received it yet.....Should be coming next week. It's bone stock and want to pump it up allittle. I have all the Variables for the AMpower ALC, AMC and all.......But I was wondering what IC PLL is in it. Does it have the MB8719 or the MB8734.........Also, I noticed there's a bright, Dim switch on face.........Is there a way to use that switch for the Upper's.......I want to get here singing and send her up to Randy (No. 1 Duckplucker)........for a loaner........He's in dire need of a SSB......NoMadRadio, I could use your expertise on this one.......Or any other comment's from you forum members would be appreciated......Thanks guys.......73's
Hmmm. A 25 year-old mobile CB. They say it's not just the miles, it's the years, too.
Gotta wonder how many miles AND mods it has acquired since 1979 or 1980. Might need to consider the "Ten-Volt Blues" if it spent a lot of time on the shelf before you got it. The ten Volt-rated electrolytic caps in any Uniden-made radio that old often wait until you have run the radio for a few days or a week before they go bad. One of them will kill all transmit. Another just kills the mike audio. Another will kill the receiver audio only, without affecting transmit. Another will roach the loudspeaker and/or audio chip when it fails. Someday I gotta put up a "scorched earth" procedure for replacing the whole list at once on those old models. Don't see how I could cover expenses selling a three-dollar bag of electrolytic caps, even if I marked them up to ten. Not rich enough to outsource it to China. Dang.
If it's really the legal 40-channel version, and NOT the 3-band EXPORT version, it has the 8719 chip and a 11.1125 MHz crystal. Same circuit board as the Cobra 142GTL or Uniden Washington. Only mobile.
The three top choices on the hit parade for added frequencies are:
1) An Expo kit. Type "B", if memory serves. Not the best choice for SSB, but relatively simple. If you can live without stretching the clarifier one whole channel, the Expo kit doesn't drift that much when used as a base. Put it in a vehicle, and the temperature extremes will reveal enough drift to be annoying. Covers 40 below and 40 above. If it's a newer kit, will show the same digits on the channel selector as an "export"-type multi-band radio does for one band up and one band down. An older Expo-100 type "B" would be off by one or two channels from what a Galaxy radio shows for the same upper or lower frequency.
2) Change the 11.1125 crystal to an 11.325 and use the fairly-simple toggle-switch mods used for Cobra 148, Grant XL/LT-type radios. Again, skipping the "one channel slide" routine on the clarifier helps make this setup more stable, even in a mobile environment. Using a center-off toggle to select the skipped "RC" channels is usually a better choice for SSB than the 'stretch-down-one-channel' routine on the clarifier. This is the most stable choice for mobile SSB use, but puts the sequence of your new frequencies in an odd order. Requires a "map" to find a particular frequency, and you can't just "scan" all the uppers in sequence looking for DX. Bottom line: More effort to use, but more stable, especially in mobile use.
3) "Try" the so-called "Six-position rotary-switch" channel mod with the stock 11.1125 crystal. This one covers from 64 channels below channel 1 up to 28.045. Doesn't mean the radio will perform over more than 60 or 80 out of all those, but it can be optimized for lowers at the expense of upper-channel performance, or for uppers with reduced performance below 1. This setup is notorious for behaving oddly when temperatures rise or fall a lot, like in mobile use. I recommend it as a base-station use only mod. Even so, one or two out of every ten radios will be 'twitchy' with this mod, losing and regaining whole sets of channels when the radio feels like it. The other eight or so out of ten will run for years before internal adjustments drift, and it starts to twitch. Requires a "map" of the new frequencies, and may get squirrelly if the clarifier is stretched too far. Should be accompanied by the center-off toggle-switch for the skipped "RC" positions on the channel selector. The reason I started #3 with the word "Try" is that you'll want it taken back off if your radio wants to "twitch" and jump up or down 64 channels after the radio's been running for an hour or so.
Pretty sure Defpom stopped making his EPROM kits. They kept the channels in a nice, sequential order, but there are a LOT of wires to hook up with that method.
Too bad nobody ever got around to making a plug-it-in "Viagra" kit for these radios.
One last thought. The Galaxy "FC-347,FC-390,FC-148" external frequency displays will wire up to this radio, but will read off by 1 kHz on USB and LSB. AM will read okay. These external displays are directly compatible with a 148, Grant Xl/LT, Cobra 2000GTL, and President Madison, but only PARTLY compatible with the Stalker 9/142/UWashington.
Wow NomadRadio, nice analysis for sure..........Thanks for all the info........I should be getting radio next week, I realize it's an oldie. Hopefully Caps are ok.........I think I must just go with the Expo kit, Type B........Just wanted to get a little SSB rig going for my buddy Randy. He's been a good friend to me, and just wanted to help him out with a little something.............I'll keep you posted when radio arrives.........Thanks again.......73's
I answered this question on the other forum I hang around on, but I will add some comments here too.
The radio uses a 15.4825MHz xtal, the PCB is PC-893, which uses the MB8719 PLL and a pair of binary adders to give it two bands of channels, I know the radio pretty well, I used to own one (sold it early this year), plus I converted one to local frequencies just last week !
It has a 10.695MHz I.F., unlike its sister radios which normally have a 7.8MHz I.F.
You only need to change that 15MHz crystal to give it more channels, BUT if you want to use a lower frequency you will need to change C142 to a 390pF and C141 to a 47pF so that the oscillator does not die.
Also, I do still make the EPROM boards, I just don't actively advertise them due to the time it takes to make them.
Hi Scott,
Hadn't thought about the "export" version. It's a newer design than the 1979 radio in Sams CB-269.
Phil, it's safer to hold off buying any Expo kits until the radio is in your hands, and you can determine what kind it is. It's probably been ten or 15 years since the last 'export' version came through here. If this turns out to be the later type, the Expo kit won't be any use at all for that one.
Hey Thanks guys again for info......I still haven't received radio yet, it should be coming any day now.........Hey wait, I think I hear the UPS truck Now.............LOL................I'll keep you posted.......73's
Well I was right, it was the UPS truck.......Radio has arrived.......Very clean rig......Pulled cover off to take a peek........Very nice.........Clarifier is already unlocked with a full 5kc slide up and down........Limiter is removed :( TR-32).
It's deadkeyin' 4 watts and swingin' to around 12w on AM.........SSB is swingin' a round 15 to 18w... ALC was cranked.....I kicked her down a touch.......Modulation was kickin' pretty good on my Dosy's.......If power mic was installed it might be a little to much with TR-32 yanked......I notice it has a 11.125Mhz rock right next to the PLL........I didn't realize that there's no variable dynamic knob on face.......But the stock mic has a volume control knob on side..............I talked to Randy and want to get it out to him towards the end of next week............... 73's all
:D
never really could understand why those uniden folks would leave mic gains off radios ? Not that Uniden made the Teaberry board or not ? especially sideband radios like the Cobra 146s /PC-122s ect.,I had the Stalker 9 DX years ago ,and if I recall it had 40 channels above 40 but no damned mic gain !! that part I do remember .....cost cuts maybe ? I just saw a radio the other day , I think it was a Voyager ? looked a lot like the old Galaxy Pluto ........no mic gain on it , but it had everything else . Go figure ?
So there is a US version as well, that confuses things a bit !
So, lets get this straight, there is a:
US version (PC-???)
US "export" version (PC-893)
UK version (PC-893)
I had not come across the US version, so I did not know it existed, I have the UK version in a box somewhere, and I sold my "export" version earlier in the year.
Can you tell me the PCB number of the one you just got, so I can make a note of it, my guess would be PC-385 based on that crystal freq.
the early stalker ix had the same board as the early mckinley, baby grant, cobra 2000, early cobra 148, madison and stalker xx, plus a good few other radios, the ones we had after 1981 had the pc893 same as late mckinley, with proms and separate oscillater board for our uk legal fm band.
Hey Guys, I pulled cover off one more time to see what board was in it......Towards front of board there's PC-385 AE......The crystal next to MB8719 is a 11.1125Mhz.......If I were to put a Expo kit in place of the big rock next to PLL......Wich expo kit do I need??? Thanks for all input fellaw's.............73's :wink:
Nope. The 2000GTL has a double-conversion receiver in AM mode. SSB is single-conversion in all of them.
The Stalker is like the 142GTL, Uniden Washington and Tram D300. Single conversion in ALL modes.
