Random wire question
Singularity35
DU7DVE
Jan 16, 2014
425
90
138
Small City, Philippines
Hey guys, I need your help again.
We are moving house once again. I may not be able to immediately put up an antenna where we're going but as a crazy ham, I'd still want to get on air as soon as possible. I'm thinking random wire into my tuner. 40 meters is where I want to operate in. How long should my wire be or is there any length that I should shoot for? Thanks in advance.
Not sure which tuner you have... does it have a balun? I run a 9:1 unun on my random wire, and only had about 50 feet to run it. See if this link works (it's where I got my unun and wire calculations):
http://www.balundesigns.com/content/Wire Lengths for 4 and 9-1 ununs.pdf
73,
Brett
i have 2 of the 9:1 unun's one is hooked to a 33' wire hanging in a tree and the other is a sloper from the top of my tower down to a tree 72' long, both work fine and have no problem making contacts on most of the bands
Thanks for all the quick replies, much appreciated.
73,
Brett
My tuner is an MFJ-949E. It's supposed to be able to handle a random wire. It has a terminal at the back for a random wire but I've heard that there are some lengths to avoid, for instance a half wave on the band I'm operating on.
I probably can't get a commercial unun because shipping from the states takes a long time to me and by the time it gets here, I'll probably be able to figure out a way to put up a loop or a dipole.
Is an end fed antenna the same as a random wire?
I don't know that an EFHW is a "random wire" however.
Exactly. An EFHW is precisely measured to make a half wave. A random wire is simply that. Random. Take a roll of wire and connect it to your feedline/antenna coupler and start walking. When you get to a convenient end point stop. Cut the wire and hoist it up. THAT is a random wire. It is self explanatory. Random.
Reactions: Beetle
Exactly. An EFHW is precisely measured to make a half wave.... Cut the wire and hoist it up. THAT is a random wire. It is self explanatory. Random.
... or you could just spin the VFO a bit and ............
Thanks Cap, I think I get the difference between an end fed and a random wire.
Any lengths to avoid or to go for if I want to operate on 40 meters?
You should look at the CHA EMCOMM II. It's 60' wire antenna end fed. It can be installed just about anywhere and will performance great:
http://www.eham.net/reviews/detail/10895
http://chameleonantenna.com/BASE ANTENNA/CHA EMCOMM II/CHA EMCOMM II.html
Carl
  • @ Spanish:
    Where do i upload schematics
