Ranger 2980wx
RugRat235
May 1, 2005
79
hi its been awhile since i visited this forum. i'm interested in the 2980wx. anyone have one that can give any info? what board does it use and what other radios use the same board? is it good on ssb? any info good or bad would be great. thanks.
i am running the 2980wx now and they are a sweet radio. i have never once had a complaint on the ssb quality of thuis radio and that is about the only mode i use for communication. receive on them is excellent and has really good frequency stability. i would reccomend this radio any day of the week. but the only thing that i do have about the 2980 is the filtering system for ssb. the anl/nb does not seem to wok very well on ssb at all other than that they are top shelf!
2980wx
yes it changes when turned,pretty good radios , after a year and a half i sent mine in for 4 different minor problems came back all working but now mudducking they pickeder back up and bump it up a little for me now its working like new again, id say go for it buy 1 10-4
That's where I do all my buisness at... Bob's is a terrific place to work with... When you get your new radio let us know how it works! I have a friend interested in one.
i got my radio today. seems real sweet. i got a couple of questions though. do you guys have any luck with the weather band on it? not sure if mine isn't working or just not recieving a signal. when i turn it to weather mode the display goes blank? it says it will scan the weather band automaticly but dosn't seem to do anything? also the green red tx/rx light blinks on recieve but stays on in tx. any opinions welcome.
i got it working .there is a weather antenna nearby. i'm not sure what i did i hooked up my scanner antenna to it and it pickup the weather stastions then went back to the cb antenna and now it works? i live up very high and on my scanner can pick up 4 different weather transmiters so i thought the local one at least should come in.
