Ranger 6900f 150 amp question.
Ed c
Aug 10, 2020
2
2
13
44
I have a 6900f 150 that's done but the amp on the bottom cover still works.. Can I take that off and use it on another radio?
Just don't bolt it to a radio with two final transistors. It was meant only for the drive level from a single final. Driving it twice that hard will shorten the life of the RF transistors.
Using the hookup to the old radio pc board as a guide will work best if the 'new' radio has the same or a similar circuit board. And if it's very different the skill level needed will be higher.
Upgrading a carburetor is always easier when the mounting holes line up same as the old one.
Reactions: Wildbill63 and Rwb
