I was comparing the schematics of the EPT360014B and C, and noticed that the mixer changed from TDA6130 to SM6130. Comparing the TDA6130 pinouts to the EPT360014B schematic, it seems like the C schematic correlates better to the TDA6130, for example: on the B schematic, the tap on the transformer is connected to pin 5 which is NC on the TDA6130, but the tap shows shows connected to pin 4 in the C schematic. Also, the Ranger parts list says "Use S042P", which (when i looked up the pinouts) correlates with the B schematic. Should my radio have the S042P IC in it? How is it working with the TDA6130 IC? Does someone have a link to the SM6130 datasheet? I've searched but all I find is MOSFETs. No mixer. Hopefully someone can clear this up for me. I'm sure there is some history in all this that I am missing. I've attached images for reference. Thanks in advance.
TDA6130 pinouts:
PCB B installation:
S042P pinouts:
PCB C installation:
TDA6130 pinouts:
PCB B installation:
S042P pinouts:
PCB C installation:
