ranger sra198 problems
123kid
328
36
38
43
question about a sra198....i bought a sra198 wired 4 pin and connected to my stryker 955 my radio tx's but no audio.i tested in car on my 505 and same thing i then tested my 505 stock on my 955 same thing no audio....yet my 452 works on both my 955 and 505 i dont understand?
The Stryker is wired just like my Uniden 505 and Galaxy.
Pin 1 ground/shield
Pin 2 Audio
Pin 3 Transmit
Pin 4 Receive
Check for a bad mic wire or mic.
Stryker SR-955HPC
Did you get a 198 with the Galaxy pin out?
P.S. The SRA-198 will attenuate your audio quite a bit so you may have to turn up the mic gain. In the Uniden 505's case you want a Road Devil on that one.
Pin 1 ground/shield
Pin 2 Audio
Pin 3 Transmit
Pin 4 Receive
Stryker SR-955HPC
galaxy, cobra, uniden are all the same wiring diagram. you,ll probaly need to max out
mic gain or close to it. if that dont work check the wire on pin 2 audio wire
I have this Mike Ranger SRA-198 and I had the same problem, I decided to remove the 22nf capacitor and the 4k7 resistor, the gain improved a lot. Problem solved.
