RCI 2990 AM Modulation
  • Thread starter Thread starter alvoid9610
  • Start date Start date
A
alvoid9610
Guest
I was wondering if anyone knows what the AM modulation limiter transistor is in the RCI 2990 base?? I do not want to remove the Q32 because it causes a loud snap in the key up of the radio if it is removed. I only want to remove the AM modulation limiter resistor. Any help would be greatly appreciated because I have been searching everywhere.
Thank you
instead of removing the amc, turn it up and add a base mic like a d104 or tuner plus 3, you will be loud and cleaner, not to mention you will still sound good on ssb
  • @ heartbreaker3473:
