Thats a high power (100 watt rig) so you would need something that handles that drive power some of the competition boxes like xforce magnaforce ETC need driver amps to achieve maximum PEP output which your high power radio will do just that.
The other types of amplifiers that take this drive power would be Amateur Radio amplifiers but then you would need a keying exciter to key the amplifier up those can be built but its up to you on what its all worth. AMATEUR AMPLIFIERS ARE GOING TO BE A BIT PRICEY BUT FILTERED BETTER THAN MOST SPLATTER BOXES YOU CAN BUY OFF THE STREET OR NET.
As others have said. Use an amp that will take a 50 watt key and you will be fine. You try and use the 2995 with "CB amps" with the key set low like 2 or 3 watts, swinging to 150 watts then i promise you,you will sound like dog crap. Try a big Heath kit,Drake or Henry. There not cheap but they will do the job.
A friend of mine runs his 2995 into a big Henry and its sounds top shelf!
