RcI Ranger 69 base " speaker or recieve dropping out" issue
Danzik
I Support WorldwideDX.com!
Oct 18, 2022
375
88
38
48
Hi all I have a Ranger 69 base that the recieve sound keeps dropping out until keyed up then a few minutes it does it all over again, I have heard it is a common issue on these but have not read anywhere what is to blame for it or how to go about the repair? Anyone have any ideas or comments on this ? Thanks
I had a few radios do this and cleaning the external speaker jack cured it on most (those with a relay, swapping that out for the rest). The RX sound passes through it to the internal speaker. Try plugging in an ext. speaker to confirm this theory.
Reactions: Danzik
Yeah, I tried that thinking that might be the issue, I didn't clean it but plugged a external speaker in and still had no recieve unless I keyed the radio again, I also tried the headphones jack as well. Thank you
Reactions: VMC
I messed around with the radio a little bit last night for a few minutes, I didn't get the scope out and check the audio chip yet and it may be the culprit. I caught it with very low recieve and flipped the radio over to PA and I didn't have any audio with a external speaker on the PA jack so I flipped it back to AM keyed it and the recieve kicked back in then I flipped back to PA and had mic audio there then ! I started looking over the radio farther and noticed one of the black wires coming from the mic connector that goes to the mic gain pot was very loose at the solder joint on the pot board so I touched that up and it hasn't lost recieve volume since, I sure dont know what that would have to do with the recieve!!!! But.... it kinda seemed like the longer I used the radio the longer it would stay good perhaps it is a weak cap or something somewhere too, we'll see what happens if guess
That's a through hole board and for years have been known to be plagued with bad solder joints. If it's working fine now I'd just reflow suspect areas like you've already done.
You got hit with a classic case of Rangeritis!
Reactions: Danzik
