RCI2970N2 mic wiring needed
LightFoot
Dec 28, 2008
91
3
18
Hi, Im trying to wire up a RF Limited Xtreme 2018 mic to this 6 pin radio RCI 2970N2. I need the the actual color to pin number. What color on 1 what color on 2 and so on. Thanks And Happy Holidays..
Hi W2EKG thank you so kindly. I had posted in another forum and got the same wiring you gave me. The Mic works great on my radio. Love this forum. Great folks and a lot of knowledge. Happy Holidays..
Reactions: W2EKG
Did you try google first? No offense but this is a 2nd-grade level search engine type of search. We all ask questions on this site but sometimes you should at least attempt to search this yourself before asking for the answer's to the homework without first attempting it on your own. This is not some oddball obscure radio that needs a different switch type or the like. It would be like going onto a site for automotive repair and asking what size your lugnuts are without first attempting to figure it out yourself. Our asking what size tires your care came with from the OEM without first checking the tire itself on the car or the data plate riveted to the door sill!
Since you know how to operate a soldering iron and you know how to use the internet and a computer surely you did not even attempt to find this info online.
I am going to tell you the same thing I tell my 3 boys! At least try to figure it yourself before you look for a cheat or the easy button. Anyone can get the answers to a test or questions in a book online but learning to think for yourself, research for yourself and troubleshoot for your self before you raise the white flag is priceless.
Please do not take this too harshly this is not meant to bust your balls but to encourage you to do due diligence first.
https://www.google.com/search?rlz=1...1.64.psy-ab..0.2.235...0i7i30k1.0.Iapgjk03aS0
https://www.bobscb.com/PDGManuals/RCI2970N2-OwnersManual.pdf
https://www.bobscb.com/PDGManuals/EC-2018-XTR_Owners_Manual.pdf
It took about .02 seconds for each of the above results and about 10 seconds for each cut and past. Surely your could have done that yourself.
Millennials cant screw in a lightbulb unless they can see the socket and someone tells them which way to twist the bulb! LOL
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
