Re: Courier Centurion 40D
dxing.bruce
60
Hey: Gang.
Had a buddy brought me an old Courier Centurion 40D.
It transmits on AM but not on SSB.
No tx on SSB is due to not transmit audio.
I have not recapped the entire radio yet but I did replace all the electrolytic caps
in the audio section & replaced the audio chip as it was pitch black from
overheating I guess.
Anyway after replacing the above mentioned parts I still have no receive audio or transmit audio.
It will only tx on AM.
What is the tiny relay in the back corner for ? is this in the audio path ?
Any suggestions would be greatly appreciated guys.
Thanks.
Bruce.
Hey: Gang.
Thanks.
Bruce.
The relay is in TX. This does not explain why you have no RX audio. The first point of failure with a toasted aF amp, is reverse polarity. Check the AF amp IC you just installed. Scope the input and output. If you have signal in, then look at out. If nothing, isolate the output and check. If you do have out, then look for shorts after the chip.
GL,
SL
Reactions: dxing.bruce
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
