Realistic Trc-456 reducing power output or variable dead key mod?
Thank you for posting that SAMS. i tried searching for it but the search function on this forum is not so great.
so the diode you are looking for is D-506.
the AMC is VR8.
you'll want to peak the transmit before you do the mod so you will end up with the desired deadkey level without detuning any coils.
peak L901 for max deadkey. peak L903, and L905 for max PEP modulated wattage.
Don't touch F901.
LC
  • @ Hambones amps:
