Remote Control Kenwood TS-590?
2RT307
Nov 22, 2011
2,439
943
223
Texas
Hi guys, I've been strongly considering buying a new TS-590 for my base setup. I travel a lot, and was thinking rather than dragging along an IC-7000 or FT-857D in my suitcase, that I would use the TS-590 remotely via computer. I see there is a software program at remotehams.com, and I know Kenwood offers software as well. Have any of you operated via remote, and how did you do it?
73,
Brett
I've been looking into doing this as well. I've had my 590 for around 2 years and I still don't know everything it will do. I'm liking it more and more. Tried to sell it once, but glad I didn't.
I know you buy and try a lot of different rigs, and only keep the best. Can you tell me what you like most about the 590? I am in the Atlanta area this week, and hoping to stop in at HRO to check one out. Have been considering the Yaesu FTDX1200 as recommended by a forum member, but still leaning toward the Kenwood.
73,
Brett
Stopped in at HRO today. I have to say the Yaesu is much more impressive in person, and pictures really don't do it justice. I'm not really referring to the display, either. The whole feel of the radio is very good, maybe with the exception of the VFO, which was pretty free. I'll have to check if there's a tension adjustment for it, because it made it a little difficult to tune. Fun to play with the filters and "see" them on the display. Very quiet receiver compared to the Kenwood (without using DSP, that is). I had pretty much made my mind up to get the Kenwood, but now I'm not so sure. One drawback is that to hook it up via USB to your computer, you have to use a converter (SCU-17) that they want 195 bucks for. They do include a serial port. (Gee, thanks... all the new computers use serial ports!) Then if you want the FFT-1 for RTTY/PSK31/CW decoding, you have to pay extra for it, too (189 bucks). So to get dressed up for the big dance, you're looking at $1884!
The Kenwood is really small. I guess that would be an advantage for field day or mobile operation, but the thing is really heavy despite it's small size. I liked the layout of the controls, and you don't have to use the menu to hit what you need. Played with the filters, the two noise blankers, the ANL and it's settings, etc. Reading the manual, they designed NB2 to kill the China Dragon... whatever that is. :laugh: Nice rig, and it seemed to receive better to me than the Yaesu. I know I was only there for a half our or so, so it's hard to really judge. Also, the Kenwood has a USB and serial port for computer connection built right in, and offers the remote control software, rx/tx 16 band eq, band scope, can run digital modes via HRD, etc. at no extra charge.
I really didn't look at the remote-ability of the Yaesu due to the higher cost for hooking it up to a computer. I guess you could use a serial to usb adapter to avoid the added cost of the SCU-17, but it really seems to me that these days, a USB port should be standard.
No decision made today, except for considering not buying either one! lol
73,
Brett
I ran the TS-480 remote using the Kenwood ARPC software. The 480 was connected to a computer (at the remote site) and used my laptop to control the 480 remotely. It worked, but as KG0MN mentioned, any network bottle neck can cause problems (especially for CW). You need a fast internet connection on both ends. This setup will work with the 590.
I didn't want to use a computer at the remote site so I bought a RemoteRig (www.remoterig.com). I connected the 480 directly to the RemoteRig "Remote" box and didn't need a computer running at the remote site. I still used the ARPC software to connect to the 480 remotely and this set up worked fine. Again, this set up will work with the 590.
Later I purchased an additional control head for the 480 and connected it the RemoteRig "Control" box. This setup doesn't require a computer at all. You operate the 480 just as if you were in the room with the actual radio. You can connect the "Control" box to a computer for logging, rig control, digital modes etc. This set up is great for travelling.
I'm now using the Elecraft K3 and K3/0 with RemoteRig. I'm controlling my amplifier (solid state, auto band switching), and an auto tuner (it will auto switch 3 antennas)
The RemoteRig is a great solution for remote operation. Setting up the router at the remote site is a little complicated but the instruction manual does a good job of walking you through each step.
Good luck with your project.
Reactions: 2 people
928bolo, thanks for that information! It is very helpful. The nice guy at HRO (Ray) in Atlanta gave me a manual for the TS-590, so I was able to read how they recommend hooking up for remote operation. I wasn't aware of the remote rig hardware, and will check that out. I don't plan on doing CW, but also understand the the latency could be a real problem on SSB as well.
73,
Brett
