RFX95
743SEPA
182
97
38
65
Etown,Pa.
Getting interested in the rfx95 add on for one of my exports. The install sounds pretty straight forward. Where would I pick up the +8 volt transmit voltage for the blue wire,say on a AT55555?
I have no idea and I can't help you with that radio cause I've not yet worked with one. I've put that in a Cobra and what I did was just probe around the jumpers on the board with a voltmeter until I found what I needed to get the 8v transmit, actually only got 7.5 volts I believe but good enough to activate the relay.
It's a thought I guess...
