rk-56 mic question.???
1iwilly
Dec 7, 2008
924
657
103
64
is there a mod or way to boost the audio on these mikes=rk-56. the 636l sounds too tinny and the rk56 is perfect but seems low on audio compare to the 636l????
The 'SkyThumper' N/C mic is cheap and works exceptionally well too. The RK-56 is still the 'top of the heap' for quality-sounding N/C mics though. A RF Limited CR-577 mic is cheaper and comparable to the 2018Xtreme mic. I use one in my mobile; think it is great. Works somewhat like a N/C mic, in that you need to keep it close to your mouth - unlike a D-104/MM6. But they are thinly built; use care and don't beat it up is all . . .
thanks for the replies could it be that i need to run the mic gain higher than 12 oclock.???
Won't hurt to try it, and it's cheaper than a new mic. If you know anyone with the Sky thumper 65-DX I recommend you try and borrow it for a bit. I have found they offer close to the same deep tone as a real RK 56 but also offer alot more audio, they claim 30% more. I have found that Billybob and Sketters microphone audio reports show the 65-DX to produce the same loudness as a D104 M6B set on level 6 but without the battery, high tone and switch noise associated with the D104.
if your audio is low and you still have some room left on the mic gain , turning it up is what to do , just don't let it over modulate . what radio are you using ? has it been tuned ? if so , who did the work ?
Yea what Booty said. Years ago when I ran a Magnum Delta Force I told the guy that tuned it I would be running an RK56. He gave the modulation pot an extra bump because he knew the RK56 would clamp it down a tad. Was an outstanding talking combo.
