Rotor Help !
sanman
Sanman
Nov 7, 2009
101
14
Carmel, Putium County, New York
Hello to all ;I need help about a TR-44 Ser. 2 rotor . The rotor works when I bench test with a 5 ft. wire (2/18-6/22 size)but when I put 90ft. on it , it doesn't move. I changed the two Caps in the control box, 0ne A.C. the other D.C for the motor start. I then put the 5ft. back and it works. Help is needed from the gurus at hand !!! Thanks!
P.S. I do here a hum in the rotor with the 90ft. cable when activated to rotate with switch.
