Hi, Y'all! I just got in an SBE Console II yesterday and after a little cleanup and hosing out the pots and switches it works like a charm (looking for wood to knock on)! I have one question, though, and I can't find an operator manual anywhere for it.
The switch that governs the meter has a "CAL" position which on all of my other radios you use this setting to calibrate the SWR meter. There is no cal/set pot that I can find so is this something that hides under the cover?
If somebody has a PDF scan of the operators manual I would be grateful for a copy.
Regards and 73,
Justin B.
Regards and 73,
Justin B.
