shooting star225+ HELP PLZZ
gee no answer on this question, someone has to know the value of those 2 resistors for the power select switch?
What are the Values of the 2 resistors ( Can be seen on bottom pic above for the Low MED High switch? they are brown and has IRC labled on them) I know they are 5% 2 watt. but need the ohms
if you are talking about my question, my transistors are good, just that the low med high switch don't work and the one resistor I believe is a 150 ohm 2watt, but I don't know what the other one is, possibly a 270 ohm 2 watt?
thanks
