Since the solar cycle is "on the way down" I thought I would ask...
guitar_199
Mar 8, 2011
1,083
1,522
173
Deer Park, TX
To those with lots of experience who have stayed "active" through all the years.........
When the solar cycles hit "rock bottom"........ does 11m do anything at all??? Ever???? Or is it "flat dead"!!!!!!!!!!
I was just sitting here thinking about antenna topics and one of them is NVIS (near vertical incident skywave).
This tends to happen when antennas are mounted "closer to the ground than is normally ideal"! Apparently ... closer
proximity to the ground causes the wave to take off at an angle MUCH closer to straight up...... which causes a "skip" to come down
in a closer radius. Or does THAT KIND of reflection go away during solar lows?????
Just kind of curious about this and thought I would ask....
Bob
I've been on and off 11 meters from western Canada for over 40 years now. While there is way way way less happening during the bottom of the cycle I don't remember the band ever being completely dead for more than a week or two....maybe a month at most.
There's no F2 skip to speak of during these periods, but E-skip can still be active during the bottom of the cycle, as can both TEP and aurora skip. It'll be dead for days in a row and then there'll be some little opening to somewhere for a while, then it dies again.
From out here on the far west coast places like California, Hawaii, and Australia can all be heard (and talked to) during the dead part of the solar cycle.......just nowhere near as often as during the more active parts of the cycle.
One thing I will say, is that having a great location and a REALLY GOOD ANTENNA matters big time during the bottom of the cycle. When the cycle is at its peak you can work the world on a wet noodle and a few watts. At the bottom of the cycle skip is marginal when it does happen...... so having the equipment, location and antenna to take advantage of it is paramount.
If you live in an urban area, or in the bottom of a valley, or have 5 S units of noise all the time, or use an inside antenna, then forget about it and put the radio away for the next six or seven years. If you're out in a rural area with low noise and a big antenna you will still be able to work skip, at least occasionally.
And regarding NVIS.....that only works on frequencies below 10 MHz or so. Not much use on 11 meters!
Been doing Ham and CB for a long time now. At the bottom of the cycle there is less activity for sure but, when the sun spot number goes up there are awesome openings but you have to be there for them. On 11M I have always found the local rag chews go way up when the bottom of the cycle happens and the same for the local Techs on 10M as well. Even if the solar weather predictions say its going to be bad keep the radio on anyway as I have had some great propagation when the solar weather was going to be horrible. Just my two cents worth!!
As you hit ham too..... I have wondered.......
Does 20M still work during the solar bottoms??? Or does it go away too??
Reactions: Eldorado828
20m is still reliable for DX during the solar minimum. It may not be open to the whole world 24/7 as it can be during the solar maximum.
Reactions: Illahe
I did some checking last night and they say we won't bottom out until around 2030-2031 so we have about 3.5 more years to ride this cycle and fall is almost here. Skip has been crap here lately so thanks to projects to keep me out of mischief.
Reactions: 45 North Florida
Well good! I don't have to renew my ticket until 2032... so that will be at rock bottom!!!!! I definitely have to get my radio set back up and get the 40m EFHW back going!!!!! (sorry for ham topic talk on here!!!!)
Reactions: Tech5 and FlyBoy50
LOL No problem with ham talk here, we all share the air waves and are suppose to all get along. I'd love to get my ticket if I didn't have so many projects going on keeping me from focusing on study. I did that once to get my Waste Water Treatment license and it wasn't fun. It's called having too many Irons In The Fire. I have to break stride now and put my Motorcycle Repairman Shoes on to get my motorcycle ready for inspection. Never a dull moment !
Reactions: jrd426
Conditions have definitely changed for the worse, but I still make the occasional contact. I don't monitor my radio like I used to but I do keep it on when I'm home. Like yesterday, I was working on a non-radio project and had it on. I made contact with a few stations in the Missouri and Kansas area. Close for me..
It's like @BC Coyote said, the E - skip is still there. I think it will pick up a little this winter, but nothing like it's been over the past several years.
Reactions: FlyBoy50
I know what your saying Brother, DX has got worst lately but I did try a little this morning. First the DX 2547, Q6 Pro both spotty. Then I seen one of my Galaxy 979s setting on the shelf and couldn't resist giving it a whirl. I lucked out with it and made a mild Orlando Florida contact with it we could understand each other but not loud. Better days are coming ! ( Hopefully )
Reactions: Brother DXer
I really like 40 meters. It is a lot of fun, you can pretty much reliably talk to someone a state or two away, night after night. 40 meters is good for when there is no conditions, you can still play radio. To me its fun to make a contact on 40 meters that is only 100 or 250 miles away. Also I have easily made contacts to both the east and west coast on 40 at night only running 100 watts and a wire antenna. I don't have an antenna good enough to really use on 80 meters, so i don't have much experience on 80, other than listening.
I have an EFHW cut for 40m on the house. I guess I was dumb in mounting it under the eave.... just behind the facia board.... it works... but not well. But it is good to know 40m does leave us some options!!!!
