sirio vector 4000 antenna question???
radioman24
449
34
38
I bought a old sirio vector 4000 i had sold to a friend about 4 years ago, and the issue i am having is after i put it up my dang swr is a 3.5 on channel 40 so what is the length suppose to be on the top stinger for a good match on 27.405mhz??? also what measuremet should the gamma rod be at??
Thanks,Dan
Thanks,Dan
24, Bob85 should be able to help you with this one. To me, it sounds like a construction error and I'm not real sure it is all in the length of the radiator, because I believe Bob85 gets his tuned at lengths from 27' to 30'+ with good SWR. That is pretty high SWR for an antenna that is made for 11 meters---assuming your construction is what the book says.
