So I want to build a 4 stacked or 8 stacked Halo for 2m SSB
mr_fx
Sr. Member
Oct 8, 2011
1,536
172
173
Kansas City
So I want to build a 4 stacked or 8 stacked Halo for 2m SSB... But I can not seem to find much info on the subject. seems like most people stop at a 2 stack, mostly I would guess because of the complications in teh phasing harness above 2 halos...
Any 'light' reading you could recommend?
Well...
You can Look into M2
=>> http://www.m2inc.com/pdf_manuals/2M HO Loop.pdf
I Know it takes up little room..
But also is little gain (even in a Stack)
Here is what i would
2 Meter 18 Element SSB Boomer Yagi
consider ..
http://www.gulfalphaantennas.com/Product Page 2 meter 18 el ssb boomer.html
However if you are trying to avoid a rotor and a large antenna.
Then this would be hard to use...
But look at the spec's..in a single antenna 21 dbi ( not bad at all )
This though is some good reading...
Perhaps what you are looking for..
This site shows stacking 4 (2 above and 2 next to )
Untitled Document
Here they talk of stacking 4 70 cm
easy enough to make instead 2 meter
A Halo 4 Stack for 70cm on the Cheap - KR1ST
I was surprised ..
Not a lot of info on those antennas for stacking..
That should give a bit though
