so new to this!! I need help! please
Hi ,I need help..I never been online Im looking for mods for a midland 13_882b could you be of help?
Welcome to the forum. Unfortunately, this isn't the correct section for this question so you probably won't get much help here. Furthermore, I doubt you will find many mods for that radio, and if you do, they will probably be expensive. What mods are you wanting?
You could turn up the modulation.
13-882B:
AM Modulation, Adjust RV2 or *Cut D10. RV2 should be a variable resistor otherwise known as a potentiometer.
(*not recommended that you cut diode 10 unless turning up RV2 all the way and adding a power mic doesn't net you 100% modulation)
AM power, Adjust L8,L9. (You shouldn't have to mess with these inductor cans unless someone max'd them out and you want a lower dead key)
more info here: http://www.cbtricks.com/radios/midland/13_882b/index.htm
